Relay disconnects from LAN after a while
  • Hi.
    I have a Shelly 1PM that is controlling a bathroom extract fan with an external switch acting as an edge switch. This all works perfectly for some hours, but then, suddenly the IP-adress is not available, and I have to reset the fuse to get it working again.
    I have tried two relays now, but both of them disconnect from my LAN after a while.
    I also have a relay that controls my water heater, but that has never been disconnected.
    I do have a Google mesh-network that might mess things up, with multiple nodes in range with identical SSIDs.
    I have a log from when it disconnects, but I see nothing strange here.
    My settings:
  • hey, pls try to set up your device an static ip.
    It could help and is recommended for all shelly devices
  • Thank you for your inputs. It seems the problem lies with the shelly homey app's "turn off" command. I used the built in timer instead and now it has been online a long time.
    Robert_M. I'm using the Google Home app to assign the MAC-adress to a fixed IP, not via Shelly settings.
