When garage door open, light on, garage door closed, light off
  • Hi again,
    Unfortunately my garage controler, cannot control the light in the garage. Using a Shelly 1 (if needed i can use any other shelly product) how do i do the wiring, and what the settings will be so that, when the garage controller open the door, the Shelly 1 to open the light, and when the controller closes the door, the Shelly to turn off the light.
    Bellow is the schematic of the controller.
    I presume, i have to bridge some how the Open and Close that goes to the Motor, with the Shelly 1, and set it as momentary switch. Now that i am thinking of it, i will need 2 Shelly1 or i will have to use Shelly 2.5 right?
    However how tha wiring will be?
    Thank you in advance
  • By its remote control device. The 7 and 8, is just to connect a local button to operated it. (currently not used).
    So i was thinking of using shelly in a way that when the command from the remote is: Open, then current is passing from 6 to the motor to open the door, and thus can trigger the shelly to open the light. and vice versa.
