The Shelly PRO 1 output is only DC?
I need AC 220V Output.
Not sure where you got this Info but from my knowledge Shellly Pro 1 has got a dry contact relay with discrete I (Input) and O (Output).
If Input is connected to 230v AC, then Output is also 230v AC.
Right, I also expect that, but I got this doubt because of the following.
In Shelly Pro 1 specs:
https://shelly.cloud/knowledge-base/devices/shelly-pro-1/
In the "Power" table there is a line:
DC output 0-30V; 12A
In the Shelly 1 specs:
https://shelly.cloud/knowledge-base/devices/shelly-1/
In the "Power" table there is no specific line about Output
This way I was wondering if the Shelly Pro 1 could be limited to DC output only, by comparison with Shelly 1 specs where that is not specified.
Can you verify this?
Thanks
yes, I can verify. this is a screenshot taken from the (not published) manual:
Thanks, so I assume that you verify and it will output AC 220V if receive AC 220V as input (sorry, I'm not expert on electric designs).
The Shelly manuals should be uniformed to avoid these kind of confusion (see links above).
