internal temperature not reported when load is fluctuating
  • Version 1.11.7 seems to have fixed things.
    would be nicve if we have clear changelogs so i could figur this out by reading instead of trying
    Hello,
    i use a shelly 1PM with factory firmware(also tried v1.9.4)
    i use it to switch on a 220-12v ledstrip(10 watt)
    when the ledstrip is on a steady color/steady load it nicely reports the internal temperature both when it is switched on and off
    However when i let the trip animate(color fades) i notice the temperature freezes and does not change anymore
    when switching off it starts reporting again.
    power reporting still works
    it looks like it can only handle reporting the power and has no time to report/change the temperature anymore
    At 17:20 it switches on with animating load
    at 20:15 i do a reboot to see if this clears things up
    at 21:00 i switch the load to asteady color at 23:15 i switch it off
    i checked with mqtt explorer and it just stops with sending out the temperature value. it only updates the power usage
    this is the powerload
    3 Mal editiert, zuletzt von GravityRZ (20. Dezember 2021 um 17:24)
