Shelly 1PM working as teleruptor (Switch only on positive edge)
  • Hi All,
    I just started testing the Shelly devices with MQTT and Home Assistant. This is going very well but I seem to have a problem to configure the shelly in a teleruptor function. with monostable switch.
    I only want the light to toggle on/off on the closed switch not on every changing state (open/close).
    Can someone point out what I am doing wrong in the configuration?
    I am working with the original fw and I am able to solve my issue using automation in Home Assistant but I would prefer if the switch would work this way as stand alone system.
    Thanks in advance!
    Regards,
    Philippe
    Einmal editiert, zuletzt von Pking (19. Dezember 2021 um 22:42) aus folgendem Grund: Some more information
