group Dimming functionality suddently stoped working
  • Hello,
    I am facing 2 issues that i think they are relevant to the latest ios app update.
    Isuue1: The monentary switch in the kitchen where the shelly is connected with the led strips suddenlty stopped dimming when I long press the switch. It goes only ON/OFF. this was working normally for many months and without any intervention apart from the app update.Firmware is not updated as the device is in almost unreachable position.
    Issue2: In the living room i have a big library with 4 shelves. each shelve is connected to a separate channel of one shelly rgbw2 device. I grouped them through the app and everything worked fine. I was able to control all channels through the same brightness bar. However now i can only control one channel. the rest are stuck in the initial position. I need to get inside each channel and adjust the brightness individually.
    Any help :( :( ?
