BUG in IOS and Android
  • Hi All
    In the new app version, I am not able to add discovered devices to a preconfigured room without connecting them to the cloud. I do not wish to use the cloud so when I select "No" when asked "Connect the device to the Shelly Cloud" the app returns to the options page without adding the device to the room. If i select "Yes" the device will add to a room as expected. The behavior is the same in Android and IOS.
  • Couldn't you just add the device to the cloud then disable the cloud in settings?
    It seems they want some initial information about the device such as where it is installed, when by whom etc
    therefore cloud is required initially I think when setting them up the first time.
    By require registering before using the shelly app further galvanizes my suspicion since if we were interested
    in using the cloud we would give these credentials at a later stage when enabling cloud connection.
