Shelly 1L at switch with no neutral
  • Hi,
    Some background on my setup. I am in the UK and have a 4 gang switch in my hallway. Each switch has the switch cable coming down from the individual lights they control. The loop (and permanent live is at the light fitting). The switch I want to automate runs 4 external lights. 3 of these lights are 5 watt gu10 mans voltage and one is a low voltage strip light using a transformer.
    1 of these lights has the wiring loop and the other three are daisy chained off this.
    Can I use the Shelly 1L in the light switch? Do I need a bypass and where does this need to go?
    Please let me know if you require additional information.
    Thanks in advance.
