Disable white channel on RGBW2
  • Is there a way to turn off the white channel when using RGB led strips? If I change collor to white the white channel is used and the RGB is turned off, this results in no light at all.
  • This is important to all users of Shelly RGBW2 with a RGB strips, we have the issue that if you use with Alexa for example, and Say Turn XX on white, shelly turn on the white channel and turn off the rgb channels, and you are not using the white channel!! The white color must be generated with the mix of RGB.
