turn off wifi / change ssid?
  • Hi,
    I've added 4 Shelly plus 1 devices to my house. Everything works great. The problem is, anyone can see the SSIDs of the devices and can know I use them. Questions:
    - is it possible to changes the SSID on each one?
    - is it possible to turn off the "Wifi mode - Access point"? If I remove the checkmark, it applies settings succesfully, but the checkmark is still present. I want it to connect to my Wifi network but without the AP being announced to anyone
  • Is a known bug. Please only set the slide switch to Disable and DO NOT press 'Apply'
    Try Firmware version: 0.9.0-beta3 - Issue should be fixed here
