Working with switch
  • Hi,
    I have classic switch with shelly 1 and shelly motion. I can switch on / off light with switch and sensor. When i come into the room the sensor lights up. When I leave and turn off the light switch, the sensor does not work for 1 minute. This is the smallest blind time value that can be set. Is there a way to make sure that the sensor and switch work and remember the latest state? Something like an edge mode for turning on and off through an application.
  • You can choose edge mode to trigger the Shelly to turn its output on and use a delayed off function of 20 seconds for example, to turn it off.
    The thing is that the motion sensor will not be ready, to detect a next motion, before the 60 seconds have elapsed.
    Therefore it's always wise to select a sensor with a short blind time.
    Oh sorry, I didn' see, that you are writing of the Shelly motion sensor, so there is not much choice.
  • Turn off the shelly1 with 60 seconds delay.
    I have it set up through the scene. When the sensor detects movement, I turn on the relay. In the second scene, the opposite. How do I turn off shelly 1 for 1 minute? Doesn't the light go out immediately or will it go off with the switch?
    So shelly motion cannot be use with manual switch?
