Shelly 1 Plus connection opportunity?
  • Shelly Plus1 is safer than Shelly1 and therefore it is approved for PELV and SELV.
    This means that e.g. voltages 230V and 24V can be operated mixed.
    An operation with 400V on the board is at least in the techn. facts not mentioned. The highest documented voltage is 230V!
    Please don't connect 400V for your own security!
    how did you come to 400 V, if two separated circuits using 230V? at least they should be separated otherwise it will not work with 12V and 230V.
