Does the 3EM log peak power?
  • I have seen some screenshots of the 3EM app, and clearly it logs energyconsumption and it can show the live power draw.
    But I am interested in history of peak power usage.
    Is it correct that I can only derive 1 minute peak numbers because of 1 minute energy consumption resolution in the logging?
    Or does it actually log peak power usage to?
    Are there also triggers/events to be set when certain power or current levels are exceeded?
    Thanks in advance
  • Well I can partly answer my question about the trigger/events.
    The 3EM API lists under actions an over_power_url to be invoked at a user defined threshold.
    So that at least is helpful, I can give an alarm and do some action, like shutting things off.
    And I can also use it for logging, although it is a bit crude.
    On the log file I find this:
    Zitat
    Shelly 3EM: /emeter/{index}/em_data.csv
    This provides an export of the data gathered by the device. For each measurement channel, a CSV file is generated with the following columns:
    • Date/time UTC
    • Active energy Wh
    • Returned energy Wh
    This will always contain data for the entire time range stored on the device.
    But it doesn't say the interval. I read somewhere that this interval is 1 minute for the first 24 hour and becomes less after that?
  • The intervall is the difference between the field "Date/time UTC" of the next entry minus the field "Date/time UTC" of the current entry.
    For example:
    Means:
    Between 23:40 and 23:50, Intervall: 10 min., consumed: 127.8 Wh
    Between 00:01 and 00:02, Intervall: 1 min., consumed: 12.24 Wh
    The current and the last day are listed in 1 minute intervalls, all days before in 10 minutes.
    Regards,
    Thomas
