Control Pro 4pm by 12V signal
  • I have four 230V circuits that I am switching using the Pro 4PM relay.
    What is the simplest way to control the Pro 4pm by four 12V signals provided from an alarm system?
    I only could come up with four regular prepended 230V relays controlled by 12V signal, each connected to the Pro 4PM bottom contacts where switches/buttons should be connected. This solution does not however look too elegant.
    Any other ideas will be greatly appreciated.
    I only could come up with four regular prepended 230V relays controlled by 12V signal, each connected to the Pro 4PM bottom contacts where switches/buttons should be connected. ...
    This is the right way. :thumbup:
