Garagedoor novomatic-563-s, Gnd Sensor
  • Hi everyone,
    I just started using the shelly uni, first project is to control a garage door or to be precise the
    "Garage door operator Novomatic 563 S".
    I have connected shelly uni and controlling the motor is working.
    But I am struggling how to check if external lamp output is switched on/off. (I have no lamp attached).
    The Novomatic manual has not much information besides how to attaching Novomatic addon equipment .
    There is a list of PINS to connect to, they are Labeled I, H, G , F, E.
    the Novomatic provides switching 24V for an external lamp but does so by switching a second PIN to Ground. First PIN is 24V. (see picture diagram 13f)
    From shelly manual looks like I could use so called GND Sensor to find out if external lamp is switched on.
    But a resistor is needed. How does that work ? What kind/size of resistor must be used.
    Thanks for your help.
    cheers Christian
    My setup:
    Shelly is powered by connecting Wire1 to Novomatic PIN 1 of I (24V) and Wire 2 to F2 ( I assume this is Gnd).
    shelly uni output 1 is connected to the PINS 1 and 2 of F ,
    switching output for short time on triggers: garage door moving up , stop , moving down ( motor stops automatic when door is down or fully up)
    shell uni output 2 is connected to PINS 1 and 2 of G , shelly output is set to always on. switching this to off halts the motor and stops it from starting.
    from the Novomatic manual
    E. Connecting the aerial
    F. (2 Pins) Connection for external impulse generator (accessory, e. g. key switch or digital coder) 13b
    G. (2 Pins) Input STOPA A break at this input end causes the operator to
    stop or prevents it from starting up.
    Connection for wicket door contact 13c
    (accessory)
    H. (2 Pins) Input STOP B A break at this input end causes the operator to automatically change direction during the closing cycle. Connection for 2-wire photocell EXTRA 626 13d (accessory). Connection for optical closing edge safety device OSE 13e (accessory).
    I (2 Pins) Voltage supply 24 V DC , max. 100 mA Connection for 24V signal/traffic light 13f (accessory).
    Connection for external receiver 13g.
    J. Plug-in base for radio receiver
    K. Connection for external lighting (with earth) or
    signal light (protection class II, max. 500W) 13h.
    P Connection for Mobility Module (accessory)
