Shelly 1 2-way wiring
  • Hi all, I'd like to find out if I've wired my Shelly1 correctly for a 2-way switch, or what needs to be done to correct it. To be honest I don't fully understand 2-way switches so I'm sure I've done something wrong.
    I live in New Zealand and a neutral wire is present in the light switch box and it's running on 240V AC.
    I've attached photos on how the two physical switches are wired into the Shelly 1 currently (bottom switch in each photo, the top one is for different lights)
    If I use physical switch 1 & Shelly app (set to edge mode), this works fine without any troubles and I'm able to toggle the lights being on/off.
    My issues arises when I turn on power via the shelly app, then physical switch 2 won't do anything (the lights flicker once but the lights remain powered on).
    I'm wanting to be able to toggle the lights being on/off using either the Shelly app, physical switch 1, or physical switch 2.
    For reference, this is the datasheet info for the switches: http://documents.portalink.net/product/190603…20HPML0595B.pdf
