Shelly 1 PM Plus connected to a fluorescent tube stop working
  • Externer Inhalt ibb.co
    I have done all connections correct on a switch to control a fluorescent lamp consumption.
    Suddenly it stop worked with damage on the the component inside the orange circle.
    What can be the problem?
    Thanks,
    sorry for my English as it is not my native language.
  • Hi,
    please upload your picture directly here in the forum.
    Thanks. :thumbup:
    ... to control a fluorescent lamp consumption....
    Technical specifications? :/
    I think you've a inductive problem,
    An inrush current limiter could help,
  • DIYROLLY can possibly say something about the defective component.
    I think the problem is the inductance and the remedy I described above for this case.
  • An inrush current limiter could help,
    Can you please guide me on what to buy and how to connect the inrush current limiter to the Shelly Plus 1PM?
    Nevertheless, I think that If Shelly 1 PM Plus has this kind of problems when connected to a fluorescent tube circuit, Shelly should advise not to do that in the technical specifications and on the manual.
    Thank you in advance.
  • jmpnm 7. November 2021 um 19:02
    Hat den Titel des Themas von „Shelly 1 PM Plus stop working“ zu „Shelly 1 PM Plus connected to a fluorescent tube stop working“ geändert.
