Reverting back to Shelly firmware, OTA
  • So I have been a long time user of Shelly 1, I have about 20 or so, going back to hardware version 1.
    Until recently they were all running Tasmota, because in those early days, that did what I wanted, and I just kept doing the same.
    Currently Shelly firmware also seems to do what I want, but with a much more non-tech-user friendly interface
    And I am thinking of reverting them all to Shelly OS
    I know how to do that wired up to the TTL-Serial. I remember even saving an original image before I flashed Tasmota.
    However, I would very much prefer doing it without having to climb up, on, under all the places I have mounted them, to remove them, flash them, and then climbing up,on, under those places again to put them back.
    Shelly did not happen to make a Tasmota compatible "coming home" firmware? Some bootstrap OTA (Over the Air) minimised firmware that I can flash into Tasmota remotely, and that then allows allows me to flash proper Shelly firmware? Similar to Tasmota "minimal image" but for Shelly?
  • Gast10 2. November 2021 um 05:25
    Hat das Thema aus dem Forum Shelly 1 nach Tasmota verschoben.
  • Did you try to flash tasmota-minimal.bin and then the Shelly OS via OTA?
    I think that this should work.
    I already flashed other firmware on e.g. Sonoff with tasmota-minimal as basis.
    Limiting factor might be the size of the firmware. But then, you have to flash via TTL anyway.
    Joerg
    • Hilfreichste Antwort
    SebMai
    28. Februar 2021 um 16:46
  • cybermaus 4. November 2021 um 08:38
    Hat einen Beitrag als hilfreichste Antwort ausgewählt.
  • SebMai
    Thanks, I try today on a test device.
    Edit: Works perfectly. Thanks
    Now to make sure Shelly cloud does everything I want it to do, in a way I can explain to non-technical users, and I can do all of them.
    Einmal editiert, zuletzt von cybermaus (4. November 2021 um 12:10) aus folgendem Grund: Reporting result.
