RGBW2 shutting it self off
  • Hello,
    I have an RGBW2 in white mode which at this moment i only control by sending http commands. This works as it should, but after a while (ranging from about 30 seconds to a few minutes) the lights go out without me giving a command to do so. I use the following command to turn the lights on:
    http://192.168.178.143/white/0?turn=on&brightness=70
    http://192.168.178.143/white/1?turn=on&brightness=70
    http://192.168.178.143/white/2?turn=on&brightness=70
    http://192.168.178.143/white/3?turn=on&brightness=70
    I'm running the newest firmware (20211004-121740/v1.11.5-gdedfb52) and have not connected the module to the cloud, or any other controller. Is there perhaps a setting which could cause this?
  • Send after turn off
    192.168.178.143/status
    using your browser.
    In the answer have a look, what is logged in "source".
  • Thanks for the answer!
    When i give the http command it says "http", but after it turned off it says "source":"input". I had set the input to "Detached Switch" which as far as i understand it, should do nothing to 4 led outputs. Also there is nothing connected to the I terminal.
