Good morning. I'd appreciate advice as to how to integrate a Shelly1 to control a Garador Garamatic 10-4 Garage door. I've attached an image of the instruction booklet relevant pages. I believe the best way to achieve control is to use the Shelly as a momentary switch, mimicking the remote control(s), For example, press to start (close or open) press to stop, press to continue (close or open)
Garage Door Integration
- Shelly 1
PeterTim -
24. Oktober 2021 um 12:07 -
Unerledigt
You can achieve it with picture 12
Search Promatic (German) here in the forum there are countless examples.
The connection seems to be identical.
Thanks Seb. Dumb question but where is the German forum. I've tried searching for Promatic at the right top of the screen, but no success. Apologies, new to the forum and website layout
You will not have found it because you have not activated German in the settings. here is a link to a post with a picture
BeitragRE: Hörmann ProMatic3
Hallo zusammen,
ich habe an meinem SupraMatic E2 es nach der ersten Skizze angeschlossen. Funktioniert bis auf die Endlage einwandfrei. Weshalb machen es manche wie in Skizze 2? Gibt es einen Unterschied?
Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. Cupras6. März 2021 um 12:16 -
Welcome to the forum PeterTim .
Please have a look into our tipps for beginners, too.
Dieses Thema enthält 5 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
