3 Way Light UK Shelly 1L
  • So not sure if anyone can help with the small amount of information I have but I have a 3 way circuit (same light but 3 switches
    Switch A
    Switch B 2 gang but the one closest to my thumb is the switch that controls the circuit I need
    Switch C 2 gang but the one closest to my thumb is the switch that controls the circuit I need
    I can't figure out where I would wire the shelly 1L
    Any help would be greatly appreciated
  • This way works from Martijn, although I could not use a push button in the intermediate switch, I used a shelly 3i instead.
    Hope this helps.
    Externer Inhalt sea1.discourse-cdn.com
    Martijn_Hoogenbosch
    Jan 25
    The Dimmer2 works exactly as the Dimmer1 in regards to the wiring scheme, so please have a look at:
    https://shelly-forum.com/index.php?attachment/12835-ar768-kreuzschaltung-png/ 285 <- three way switch
    https://shelly-forum.com/lexikon/index.php?entry/113-connection-diagrams-shelly-dimmer/ 169 for more wiring diagrams.
