There is wifi, but no cloud
  • Hi guys, several days already
    - I see the device as OFFLINE on the my.shelly.cloud
    - device is connected to WiFi
    - I browse its web interface
    - if I turn off and then on - the cloud is there but for limited time
    - I tried the Disable Cloud option and then enabled it - did not help
    - I have lost data - one day appears empty on the chart
    - the device worked a year without a problem
    - the log says:
    149685655 cloud_aes.c:256         Connect to cloud: -8
    149690048 cloud_aes.c:425         Cloud connection 0x3fff29a4 closed
    149695332 cloud_aes.c:139         Reconnect after 15000
  • Thank you Stefan but I already did that and even said that above ;)
    The first thing I did was to search through the forum.
    The things get even weirder - already 4 days I have no data in the cloud BUT the cloud android app shows some current power consumption. Alas no historical data.
    I rebooted the device many times.
    the icons at the top of the screen (when I connect directly through http to the device) say "Trying to establish connection to cloud" and "Connected to WiFi network"
    Einmal editiert, zuletzt von Nedko (18. Oktober 2021 um 16:34)
  • No, you did not, i think.
    This seems not to be the same, i wrote:
    please disable cloud via WEB-UI and reactivate cloud via app.
    Done in this way?
  • Ah, I see now, no, it was not done this way, my mistake, may be this difference needs to be explicitly emphasized.
    Nevertheless, I tried to do it now - disabled it through WebUI and when I tried to enable it through the mobile app - it waited some time and then it showed me a message with red footer stating that "This device has not reached the cloud yet!Please, ensure the device is powered and your WiFi network has Internet access!"
    I did exactly that - the device is powered and connected to the WiFi, my network has Internet access. My phone also has Internet access.
    I wonder how would it be possible to turn on the cloud of the device from the Cloud since it is turned off?
