Hallo!
Leider kann ich im richtigen Unterforum kein Thema eröffnen. Ich hab inzwischen einen OpenHAB-Server aufgesetzt und neben einem Shelly 1PM noch 6x Shelly DUO RGBW per offiziellem Shelly Binding eingebunden.
Folgende Channels habe ich für das Binding für die DUO RGBW gefunden:
| Group | Channel | Type | read-only | Description |
| control | power | Switch | r/w | Switch light ON/OFF |
| button | Trigger | yes | Event trigger, see section Button Events | |
| autoOn | Number | r/w | Sets a timer to turn the device ON after every OFF command; in seconds | |
| autoOff | Number | r/w | Sets a timer to turn the device OFF after every ON command; in seconds | |
| timerActive | Switch | yes | ON: An auto-on/off timer is active | |
| color | Color settings: only valid in COLOR mode | |||
| hsb | HSB | r/w | Represents the color picker (HSBType), control r/g/b, bight not white | |
| full | String | r/w | Set Red / Green / Blue / Yellow / White mode and switch mode | |
| r/w | Valid settings: "red", "green", "blue", "yellow", "white" or "r,g,b,w" | |||
| red | Dimmer | r/w | Red brightness: 0..100% or 0..255 (control only the red channel) | |
| green | Dimmer | r/w | Green brightness: 0..100% or 0..255 (control only the green channel) | |
| blue | Dimmer | r/w | Blue brightness: 0..100% or 0..255 (control only the blue channel) | |
| white | Dimmer | r/w | White brightness: 0..100% or 0..255 (control only the white channel) | |
| gain | Dimmer | r/w | Gain setting: 0..100% or 0..100 | |
| effect | Number | r/w | Puts the light into effect mode: 0..3) | |
| 0=No effect, 1=Meteor Shower, 2=Gradual Change, 3=Flash | ||||
| meter | currentWatts | Number | yes | Current power consumption in Watts |
Channels in group color or white apply depending on the selected mode - they are not active at the same time.
Und die letzte Anmerkung ist auch mein Problem.
Im "white Mode" ignoriert die Lampe sämtliche Versuche, die Farbe einzustellen. Aber wie bekomme ich den Modus denn per Openhab auch von White auf Color gestellt?
Das sind sämtliche Punkte, die per Shelly Binding eingebunden werden konnten. Ich habe mit allen herumgespielt, der Modus ändert sich aber nicht von "White" auf "Color". Viele der Punkte gehen nicht, bis ich im Webinterface der Lampe den Modus per Hand umgestellt habe. Das kann ja nicht Sinn der Sache sein. Kann mir jemand weiterhelfen? Vielen Dank!
Grüße
