This device is not currently supported - Shelly sensor as Alexa trigger
  • I had the Shelley sensor set up with Alexa working fine as a trigger for a routine. It suddenly stopped working and I had to reset the Shelly sensor. I finally got the Shelly sensor connected to the Shelly app again and then went to set it up as a trigger for a routine again. Now Alexa is saying that the Shelly sensor is not supported as a trigger for a routine.
    I have tried deleting the Shelly sensor device from my list of Alexa devices. I have tried disconnecting the Shelly skill and reconnecting the Shelly skill. Alexa will find the Shelly sensor and add it to the list of devices. It will not however allow it to be a trigger in a routine.
    See the sequence of screenshots below.
    The sensor is successfully connected as an Alexa device:
    The device shows that it is indeed a Shelly motion sensor.
    I go to create a new routine and add it as a trigger.
    Select smart home devices.
    Choose the Shelly sensor as the trigger device as I did a couple weeks ago with no issues.
    Now Alexa reports back that the Shelly sensor is not a supported trigger device.
    Could this have gone down because of a Shelly update?
    Any suggestions?
