Using Shelly Dimmer 2 on 220 LED Strip with rectifier
  • I am planning to control LED Strip using Shelly dimmer 2(dimming only through shelly not going to use switches), however I am confused where to connect my shelly before the rectifier or after the rectifier as shown in the below pic. also if this needs special wiring or can be connected using ordinary shelly dimmer connection without switch.
