how to dim a lamp that came with meanwhell PCD-60-700B
  • hello,
    i'm newb here, i installed some shelly 2.5 in my home and some shelly duo bulbs, all working very well, and i wanted to graduate to something more complex :)
    my in laws have gifted us a designer ceiling lamp and i would like to understand if it could be connected and dimmed through shelly/ home assistant integration
    this is the link of the lamp, with the information below given on the site about the led.
    Art.WVLUMEN°K LEDA cmB cmC cmLED
    Hula Hoop P24222072952700/300040Ø6644700 mA CRI90
    the lamp comes installed with this power supply (with integrated dimmer?) and i cannot understand if i can dim it at all using a shelly dimmer.
    my first hypothesis is that i should get the power supply out of the equation, and should connect directly the AC wires to the shelly and the shelly to the led, however i'm not sure i understood it correctly.
    i find the last page of the spec sheet confusing (attached) as it says to keep the power supply and give it commands with a dimmer, can a shelly do it?
    could someone help me understand how to make it work? :)
    thanks a lot,
    Nicola
  • Thanks for the hint but I'm afraid I'm not able to understand what to do with it 🙁... Is there a way to treat a Shelly dimmer as a triac trailing/ leading edge trimmer? Should I wire it as suggested in the last page of the attachment? If so, with a specific software configuration?
