Light on when input switched but only after sunset
  • Hello Shelly colleagues. I have used a Shelly 1 to turn on a security light using a 12v PIR but now I only want it on when it is dark i.e. after sunset. I still want to get a notification during the day when the PIR is triggered but I don’t want the light coming on.
    Any clues how to achieve this?
  • You can use a second shelly
    First option you have a bit to change in the connections and connect a second shelly.
    Second, work with scenes (second shelly still needed)
    Or use an Uni , here you have to work with scenes
