Shelly Plug S WIFI Network
  • Hi,
    I try to change the WIFI network. Unfortunately, I have no password on it.
    How can I connect the "Shelly Plug S" to my network ?
    Of course, I don't want to put a passwotk on my network
    Thanks for your help
  • Hi,
    if I understand you correct you want to run your WIFI-network without any safety-options??
    So anybody who "see" your network is able to connect (and control your devices)...
    Viele Grüße,
    Wolfgang
  • Hi,
    You are right. I have a trusted network with Ethernet/WIFI 5GHz and an untrusted network with WIFI 2,4Ghz. There is no connexion between the 2 network (except if I accept the connexion).
    Of course, if you want to connect on WIFI 2,4Ghz, you can (but this is your problem and i can see your login/password). In the protocol WIFI, there is no obligation to have a password. The only problem is the french law.
    My domoticz server is on the safety network. So, i accept a connexion http from server to Shelly and of course, the answer. All the (chineese) device can do everything on internet, I don't care
