Set "on" period for Shelly Motion?
  • SOLVED
    Answer is:
    Set "ON" time like this:
    http://192.168.xxx.xxx/relay/0?turn=on&timer=ttt
    Where ttt = time to status "OFF" in seconds.
    Note that "END OF MOTION DETECTED" has to be disabled.
    Thanks to @66er in the COLLECTION OF HTTP-COMMANDS post.
    Hi Forum.
    My Shelly Motion sensor triggers another device with I/O URL action like this:
    After being switched on, apparently the triggered device switches off after 1 minute by default. I would like to keep it on for more than 1 minute.
    Is there a way to do that via the Shelly Motion I/O command?
    In that case I am looking for something like:
    http://192.168.xxx.xxx/relay/0?turn=on/120seconds
    Or can the "on" time only be set in the triggered device settings?
    If it needs to be done via the triggered device, I have a problem, since this device is part of a scene. That scene switches the device off after ten minutes.
    I hope someone can get me started with this issue.
    4 Mal editiert, zuletzt von Elsdeniep (2. Oktober 2021 um 16:24)
