Control 2 devices from 1 channel?
  • From a I3 a want to control 2 different Shelly 1PM from the same button. Is this possible? Channel 2 and 3 will not be in use here.
    For now i use standard 192.168.x.x/relay/0?turn=on command to turn on light on one buliding but i also wanto to turn on light simultanously on another building without using a second button.
    I don't use cloud.
    Cheers, Marcus
  • Which firmware do you use?
    I'm using always the web-ui for setup. ;)
  • Well, fresh out of the box and i i never get the question to update. And yes, it have internet access with correct gw and dns.
    The current Firmware version of your Shelly device is 20200421-183805/master@d834f204 No newer firmware available.
