Shelly 2.5 - calibration failed but debug log says it was successful?
  • Hello everyone,
    I have a 3T35-10B roller shutter (https://www.3t-motors.de/3T-Motors-Roll…-10Nm-SW40.html) that I want to control with my Shelly 2.5.
    I already have four Shellys in my house that I was able to successfully calibrate.
    With this new one however, the calibration simply stops nearly at the end and my app/browser tells me it failed.
    Here is what I have tried so far:
    * set the Shelly to roller shutter mode
    * set the working time to 120 seconds
    * tried the app and different browsers
    * reset the device
    The roller shutter moves down entirely, moves up entirely, then moves to ~20% open and stops for a while, then
    * either moves to ~50% open and stops
    or
    * just stops
    and tells me the calibration failed.
    Video on Streamable.com
    In the Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. however, I cannot see any issue!?
    Firmware is 20210909-144331/v1.11.4-DNSfix-ge6b2f6d.
    What can I do??? :(
    2 Mal editiert, zuletzt von Ro4cHii (28. September 2021 um 19:50)
  • Ok so I've now wired my Shelly like this:
    When I plug in the USB, I see no difference in having the yellow wire (GPIO0) grounded or not (e.g. flashing LED on the Shelly or similar).
    I also tried switching RXD and TXD (RXD -> RXD, TXD -> TXD vs. RXD -> TXD, TXD -> RXD).
    No Matter what I do, the Shelly does not seem to connect:
    Is it broken?
  • I found some tips on GitHub and Stackoverflow, however none of them worked for me.
    Using this guide (https://github.com/yaourdt/mgos-to-tasmota) I was able to successfully flash OTA; first Tasmota, then Tasmota Minimal and then again the recovery firmware (1.5.10).
    Using this, I was able to do the calibration.
    Thank you very much your crucial hint! :)
    2 Mal editiert, zuletzt von Ro4cHii (30. September 2021 um 18:24)
