Reset of Shutter Motor
  • Hello
    I have installed a Shelly 2.5 in one of my electric shutters. The first of 9 to do. While doing the install the shutter itself learnt new limits. The Shelly correctly controls the shutter between thought limits.
    I need to send a sequence of up and down pressed to get the motor to reset itself. 1s Up, 1s down, 1s down, 1s up, 1s down, 1s Up, 1s Up and down until the bottom...
    Is there a way to get the Relay to send this?
    Thanks
  • The switch reset didn't work for me. Not sure exactly what I messed up, after disconnecting shelly and rewiring the switch as it was, the motor still works with the newly learnt limits (which is for me just ~5cm up and down). I tried with a second blind and a second shelly... same result.
