hello i have a shelly plus 1pm whith firmware 20210921-202918/0.8.1-g52de872 the websites says it works whith Home Assistant bud the shelly integration does not support this firmware are there solutions for this ?
home assistant
erikj -
27. September 2021 um 14:28 -
Unerledigt
I have a working Home Assistant with Shellies 2.5 and 1pm. You can have it working via the shelly integration. However, I prever it via the MQTT integration, so giving up the cloud of the Shelly. Majorly because of the level of realdtime this gives compared to the cloud solution.
Also the MQTT is available as an integration in the Home Assistant so very simple to install.
Set on each shelly the ip address of the MQTT server and userid and password and it is finished.
i have my shelly,s not by cloud integrated in HA its just on ip base and that works fine
so i dont need something extra like mot
the shelly integration works perfect bud i think that the new devices are not supported bij ha ore shelly doesn't have the right firmware for then i guess that's why i hope i get an answer of shelly here
i don't use the app ore something
Shelly Plus 1 / Plus 1PM is probably supported with the next HA release.. The neccessary code changed have been accepted and merged..
Yes it is implemented but when I try to imtegrate it it request username and password. But I have only password which I setted up on authentification. Same situation was with original Android App.
Dieses Thema enthält 12 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
