shelly 1 with touch addon problem
  • Hello,
    I have shelly 1 with addon and touch sensor on it. The shelly is working perfectly. I can power on and off the lights from the app.
    I can't configure the addon with the touch sensor to work properly. If the lights are off when I touch the sensor the lights go on, but when the lights are on I can't turn off them with the touch sensor. While I am pressing the touch sensor the lights stays off, but right after I release the touch sensor they turn on again. I tried different settings, but the result is the same.
    Current settings
    Power on default mode: Restore Last Mode....
    Button type: Edge switch
    external switch: Enable external switch, Flipping the switch turns output ON/OFF
    Interface icon: basic
    Regard
    Ventsi
  • perhaps this help you, please use an translator
    DIYROLLY
    15. Dezember 2020 um 17:54
