How to place 1L inside bulb holder with 1 way switch
  • Hello,
    I want to place this module but I don't have place behind the switch.
    I have a big bulb holder witch have attached L + N.
    I try to understand if I can connect the module there and what I need to operate it also keep the switch working as well.
    can anyone tell me if he succeed with this?
    I can take a live L to the bulb if need (as understood if it will connect with attached L the module not work when switch is off).
    It will be great if someone tell me how to wire it.
    I try to connect O and SW2 to bulb it work but reset the shelly Wi-Fi, also make the bulb on/off quickly (not led, so this is not because of bypass)
  • Hi Eulhofer,
    Thank you for replay.
    I draw something that work good for me as test that I made, but the problem that I don't have the wire "com" in the bulb.
    The second test that made the flicker bulb when I use the switch was when I took the same Phase to "L" and "com" as pic 2. Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
  • Yes, I saw those diagrams. Actually I have reach that forum because of a link to those diagrams.
    But it is for 2 way switch, also you can see diagram 2 is the same idea to my first test.
    But the problem is that I need to connect 2 new wires to bulb:
    one of L
    another one from the switch to bulb to connect "com" and "O"
    that because the module will be inside the bulb holder.
    so, if there is a simple way that I didn't know, or other module that can work with that kind of place (inside the bulb holder) I will glade to learn.
