connexion problem
  • hello
    i try to connect the shelly button 1 to the network. i can configure it with the android app ( add device ) the device is added ( with the wifi parameter SSID Name / password). The device is not displayed in the discovery menu ( add to room ). I can't locate his new ip in the network.
    i tested to configure directly by connecting to the AP name of the shelly button 1 (shellybutton1-xxxxxx), i use my webbrowser ( ip 192.168.33.1) i can configure the wifi client ( ssid name and password, tested with ip fixed or DHCP. But the device is not recognized, so i cannot configure an action to the button, the device doesn't appears in the android discovery menu.
    connected to usb, the blue light is blinking, when the device is not connected in usb, if i press the button, a cyan led is blinking then shut off.
    I tested to press 30seconds the reset button located under the battery.
    thanks for your help
    i tried using my smartphone wifi share and it's ok, i think my internet box is not compatible with shelly button 1 ( ? )
    ok i found the problem, my wifi box has two wifi simultaneous wifi mode ( normal and 5ghz) . The two SSID had the same name, so i renamed the second wifi ( 5ghz ) xxx_5GHZ
    the shelly button 1 is connected to the normal SSID, i can connect to it in http
    2 Mal editiert, zuletzt von openmotion (4. September 2021 um 01:25)
  • Welcome to the forum. :)
    Great that you did it yourself. :Daumen hoch:
    Nevertheless, I would like to give you a tip to get you started:
    Take a look at our help threads in the corresponding sub-forum. ;)
    Have fun here.
