Shelly 2.5 output switch
  • I have a spare output in a Shelly 2.5 and I would like to use it as an alternative to turning on a light. I'm using both switch inputs so that's not an alternative (I'm using the PIR circuit as shown in connection diagrams Shelly 2.5).
    So the question is, O2 goes to neutral when is not activated? Because if it does, then it can't be done.
    This is the circuit I want to mount with the additional switch (adapted from lexicon here connection diagrams Shelly 2.5) Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    2 Mal editiert, zuletzt von SergioS (29. August 2021 um 05:03) aus folgendem Grund: Copyright infringement
