Can not add a Shelly Plug S
  • Hi there,
    I do not manage to add a Shelly Plug S.
    What I do is the following:
    - I plug the Plug S and it flashes blue (more or less once per second)
    - I open my Shelly app and click on the top right menu and choose Add Device
    - I enter my wifi sid and password then Continue
    - The app shows my Plug S device
    - I select it and click yes when asked if I want to add it to my Wifi network
    - I get a message telling me that the connection was successful (to the device AP with the it 192.168.33.2/24), asking device to join my wifi
    - I get a message telling that the device was included to my wifi
    - I then click Finished
    - I get a message on the top of the app telling me that the inclusion was completed
    - I then go to my only room and click Add devices
    - At this point the list of my Discovered Devices is empty
    I do not see the device on my home network (no new IP is allocated)
    The Plug S flashes at the same speed than before (more or less once per second)
    But its AP wifi is turned off
    I have restarted all this from scratch factory resetting the Plug S.
    I saw in a previous discussion that the problem was an IP conflict. But here I do not see the Plug S on the network.
    My Wifi is 2.4Ghz.
    What I am doing wrong?
    What is the maximum length of the wifi password a shelly device supports?
    What could be the problem?
    Many thankd for your help
  • Hello @66er ,
    yes you guessed correctly. It is my first Shelly ! :-)
    My router is not in the list, but it is my ISP router and I think it does not mean it may not be compatible. The page does not list the router requirement or particularities it needs or does not like so that I could check.
    I see that Shelly does not like hidden SSID or special characters. I have none. My password is only alphanumeric with lower and upper case.
    Does Shelly have a problem with password length?
  • I managed for a short while to connect the Shelly Plug S.
    I could see it in the app and also on the network.
    To do this I used the same router but with some changes in the configuration.
    So it may not the router incompatibility but some parameters (maybe).
    Unfortunately I could not finish the work to tell what config in particular helped because:
    after some minutes the Plug S went offline and is now stuck.
    • It is not on the network anymore
    • it is flashing very fast blue
    • and more problematically factory reset (10 s push the on/off) does not have any effect !!!
    So I can not do anything more with it!
    The doc says fast blue flash is AP mode, but I do not see its Wifi.
    I did not find any indication on other way to reset the device.
    Would you know what else I can do to recover the device now?
    What is the type of your router please?
    What have you changed to have the plug online for a little time?
    Take the plug from power for a few minutes an try again.
    If the AP does not appear after pressing the button for more than 10 seconds, the Shelly may unfortunately be defective.
