Xeoma Security HTTP Switch module.
  • I am trying to integrate a shelly relay with a security system Xeoma.
    The Xeoma uses an HTTP switching module, I am assuming it can read and write to the shelly relay with an http json command.
    Does anyone know the http syntax for getting the status of the input terminal on the shelly relay?
    It would be something like 192.168.x.x/status/{infoxxxx
    Please and Thank you for your help.
    Thank you.
    This is the reply I get with /status, is there anyway to isolate just the input Please ?
  • Thank you.
    I am using the web browser to communicate with the Shelly relay. I am typing into the web browser the IP address 192.168.x.x and the line you suggested. The web browser seems to convert what I typed to this
    192.168.0.108/status[%7B"input":0,"event":"","event_cnt":0%7D]
    the response from the Shelly relay is the same as what I posted above.
    I am looking into starting up a security business and integrating automation with the security software. I would like to install a motion sensor to a porch light with the motion sensor also wired into the input terminal on the Shelly relay. The security software should be able to detect this input through the HTTP status. I am hoping to isolate the JSON response to only be the status of the input terminal. thank you for helping me out
