discussion about mqtt topic/payloads - 3em
  • I have just installed my 3em. It is my first Shelly product. I did update the firmware. I am using mqtt and not the cloud. I am using a custom python program to process the mqtt messages into a mysql database and I view the collection with Grafana.
    ((about my install -- My 3em is installed on the split single phase 240V 3-wire service (third CT on the neutral) the electrical coop provides. I do not have solar nor batteries. My coop does not yet do time of use metering. They do measure peak load and we pay a charge for the highest demand between the hours of 16:00 and 20:00 that is recorded during the month. I am using the 3em to shed load during that time period during the day.))
    I am trying to consolidate the 18 separate mqtt topics and their payloads into a single row in a mysql database.
    I am temporarily ignoring topics that contain "energy" as well as the relay until I find a use for them.
    These 18 messages represent the value states at a particular point in time (and I want my database row to reflect the states at that point in time). If the mqtt data reporting could be improved, I would like to have these 18 datapoints in a single json payload.
    I am currently accepting each topic and holding the payload until I have received all 18 and then I issue a database insert. A second appearance of a particular topic before all 18 have been gathered also triggers the database insert and the start of collection for a new row.
    Every so often, the 3em sends only six topics, those for total and total_returned (for each of the three CT). These same topics are also sent in the group of 18. This causes a problem for my program logic that expects all 18. Are these necessary? What is their purpose?
    I am unable to find any controls over the frequency of mqtt topic publishing. Is this event driven? Is it possible to make the 3em report more frequently?
    I am using the custom mqtt prefix to shorten the topic. The topic up to the /CT number is still quite long. I realize that the topic was probably chosen with all Shelly devices in mind, but I would appreciate a means of shortening it considerably. You can ignore this thought if you find the single json payload acceptable.
    Thank you for your time and consideration.
  • There is no fixed MQTT send interval. You get new MQTT messages only if there hase been a change.
    And you only get messages for the values that have changed.
    So you can not expect 18 messages to come every time, since you only get changes...
    So you will need a different approach. Depending on what you are trying to achive there are many options. You could store each incoming message with a timestamp in the database, or you could define a short timeframe where you accumulate data and store that.
    Typically several messages will come togehter because a change in the measured voltage or ampere will result in a change for power or energy...
    My Shellies: 15x 2,5 / 3xRGB / 2x 1 / 2xEM / 3x4Pro / 4x3EM / 4xi3 / 20x Duo RGBW E27, 10x Duo RGBW G10
  • Thank you for responding.
    I am seeing all 18 topics, even for those that have reported only 0 since I began recording (most zeros are from the CT clamped on the neutral).
    I have recorded the information for about three days. All 18 topics appear at the same time, in order, one after another. I am watching the mqtt firehose to visualize this statement.
    Though it might be a wrong approach, I am generally getting what I need from my simple python program. I wasn't able to find any documentation, so I developed code based upon my observations of the mqtt firehose. Do you know of any documentation?
    There are infrequent reports of just six of the 18 topics, as I mentioned in the original post. I'm working on some code to fix that.
    Other advice is welcome.
  • Hmmm this is interesting. I checked my 3EM (with MQTT Explorer and within iobroker) and I do not get all updated together... Which firmware do you have in the 3EM?
  • Realizing the box may have set on the shelf for a while, the first thing I did from the dashboard was a firmware update.
    Current version: 20210720-190729/v1.11.0-g6abd92e
    You have latest version on your device!
    Is this similar to yours?
