tasmota flash not working
  • Hi All,
    Im trying to flash the Shelly1 with the Tasmoto SonOFF.bin. The flashing tool ESPEASY says its done, but after rebooting
    the Wifi wont start and i cannot log into the shelly. I tried (i think) everything... does anyone know what to do at this point?
    I have a Shelly1 V3
    Hi @drogert , welcome to the forum. :)
    I've moved your topic into subdirectory "Tasmota".
    This should help that you may get a more targeted response faster.
    Have fun here. ;)
  • Gast10 12. November 2019 um 05:37
    Hat das Thema aus dem Forum Shelly 1 nach Tasmota verschoben.
  • The lastest binaries are entitled tasmota.bin version 8.1.0. Once it's flashed the shelly will create a new wifi access point on ssid "shelly-xxxx", you'll need to connect to that wifi to configure your house wifi/password in tasmota of the shelly.
    Personally, I flashed some initial shelly devices with tasmota (which is absolutely brilliant) but then stopped once shelly supported mqtt and provided continuous software updates with new interesting features (eg DDD actions). Through mqtt my shellies are made accessible to homebridge, so I benefit of both "worlds". Activating mqtt deactivates some shelly cloud features but I don't use it, I use the Apple home app for remote access to homebridge.
    I don't think the flashing process is reversible ie replace tasmota by shelly binaries, which is another reason why I left shelly firmware.
