Shelly Dimmer 2 Unable to Calibrate
  • Hi,
    I have installed 3x Shelly dimmer 2’s, all with no neutral and using the Shelly bypass.
    2 of them work fine and are calibrated with trailing edge.
    1 of them, fails during calibration. I can turn the lights on/off but then the Shelly disables itself over around 40% brightness. I assume it’s overheating so turning off to protect itself.
    The one that is not working uses different bulbs. But if that’s the problem I don’t understand why these bulbs would cause it to not work - Bonlux ST64 E27 Edison Screw Bulb 4W Vintage ES Clear Glass LED Filament Bulb Warm White 2700K,40W E27 Incandescent Light Bulb Replacements for Decorative Ceiling Antique Pandant Light 4pcs https://www.amazon.co.uk/dp/B07GQLY8JG/…ding=UTF8&psc=1
    Am I correct in that it’s the bulbs at fault?
    Many thanks
    Steve
  • So I’ve tried changing bulbs to another type. The Shelly did actually calibrate. However a bulb then popped and I don’t have proper control over the other.
    Maybe this isn’t the bulbs I’m using and it’s the Shelly itself? Any ideas welcome
    Thanks
    You are right.
    Mixed operation does not work or does not work reliably. This has already been discussed in many German-language threads
