Shelly 2.5 showing power usage as 0 watts with 3 lightbulb load
  • I just installed a Shelly 2.5. It’s showing 0 watts consumed with the load on or off. The load does turn on (I can see the bulbs). Two are CFL’s and one is a LED. It’s probably 50 watts of load. Any suggestions what to do?
  • Looks like it’s failing to read the register for the I2c power meter based on the logs.
    24146453631 json.c:420              RAM: 49272 total, 34556 free
    24148394250 ade7953.c:261           Read failed: ADE7953_REG_BWATT
    Hi and welcome to the forum. :)
    You can try to reinstall the firmware.
    If this has no success, you should exchange the shelly.
    Hi, did you solve this problem?
    After installing the latest firmware i have similar problems
    Tried some firmwares from shelly generator, but it didn't help me :(
