Momentary switch dimming and turning off issues
  • Hi All
    I've got an RGBW2 set up controlling an RGBW strip in the kitchen. From what I read prior to buying the device, I should be able to dim the strip using a long press on the switch but this doesn't work. Do I need to set up http commands for this to work? If so what are the commands to dim up / dim down in a cycle when the momentary button is long pressed because I can't find them in the reference guide?
    Also a slightly different issue, when I press the switch to turn the lights off, they take about 10s to gradually dim and turn off. I want them to switch off immediately or at least do it within a second or so. I've tried setting the transition time to 0 but it has no effect.
    thanks
