Shelly 1 - not getting any Event Log
  • Hi,
    I have a Shelly 1 for controlling the garage door, with an Addon magnetic sensor, but I'm not getting any Event Logs. The switch works fine, I have a notification when the door opens and closes and it all works fine, it just doesn't log any event.
    I checked the Application Settings and it's not excluded from event log. I already tried turning on an off the "exclude from event log", several reboots, changing the device name, but with no success.
    I have several logs from when I first installed the Shelly, but then I did a factory reset, changed the wifi settings, and after that it stoped logging the events.
  • Ok, after several resets and changes, I found this bug that if the switch has a timer, it doesn't log any event. As this is a garage door, I have a 0.2s timer to turn off after turning on the switch.
