I've tried all three firmware versions and although the app shows motion detected, it doesn't result in the lights switching
Help please!
Help please!
With your input, there is no output possible,
Sorry, but you do not give any information with which commands you want to switch on the light via which Shelly.
And the crystal ball is on summer vacation.
Screenshots?
Okay cool , at least someone is getting a vacation..
Not sure what you need for information. I have a dimmer 2 and a 1 controlling two lights . I've setup the motion to switch both on at 'any time ' .
Both lights work perfectly via the Shelly units apart from the motion
Any other information you need I'll be happy to provide thanks
Please read:
Beginner's tips for shelly and the forum
Unfortunately I still don't see any commands that have been used, I don't know what was entered under which actions, how the motion is set ... ![]()
Hi , I don't think the beginners tips are really relevant?
It's hard to screenshot the issue as the quick setup feature on the motion is multiple pages and the setup options are extensive too .
If I tell you the installation in the app is default and the motion is working (IE. The app registers movement when the motion is triggered ) - what else can I can tell you that I haven't already .
If you can ask me about any info you need over and above what I've told you over my 3 posts , I'd be happy to help .
The 'command' for the Shelly motion is movement by a body, right ? So I'm moving and the light isn't switching on . How can I be clearer than that ?
