Calibration Lost after a few minutes operation
  • ENGLISH:
    A Shelly Dimmer 2 is feeding 2 x 240V 20W halogen lamps in parallel.
    The halogen lamps were installed as replacements for LED due to the excessive and annoying flickering that occurred with the previously used LEDs.
    The Shelly Dimmer 2 is connected to the phase and neutral. No bypass is used.
    The lamps are identical manufacturer and were installed at the same time.
    The Shelly Dimmer 2 was calibrated immediately after installing the lamps, with the "autodetect type of load during calibration" option used.
    During the first calibration attempt the Shelly Dimmer 2 shut off the lamps after a few seconds and indicated overheating on the user interface. The calibration did not complete.
    After allowing 10 minutes for cooling off, another calibration attempt was started. The user interface showed "calibration completed".
    Now the problem: After a few minutes of operating the lamps at 65% brightness, the user interface showed "calibration error". A new calibration cycle was started... again the interface showed "calibration completed" and again it showed "calibration error" after a few minutes of operation. When using the App to control the Shelly Dimmer 2, it always shows "calibrate before first use".
    Does anyone out there have a similar problem with calibration showing "failed" during operation of the lamp after a successful calibration cycle? Does anyone have a tip how to resolve this problem?
    DEUTSCH:
    Ein Shelly Dimmer 2 speist 2 x 240V 20W Halogenlampen in Parallelschaltung.
    Die Halogenlampen wurden aufgrund des übermäßigen und störenden Flackerns der zuvor verwendeten LEDs als Ersatz für LED verbaut.
    Der Shelly Dimmer 2 ist mit Phase und Neutral verbunden. Es wird kein Bypass verwendet.
    Die Lampen sind herstelleridentisch und wurden gleichzeitig verbaut.
    Der Shelly Dimmer 2 wurde sofort nach der Installation der Lampen kalibriert, wobei die Option "Autodetect-Lasttyp während der Kalibrierung" verwendet wurde.
    Beim ersten Kalibrierungsversuch schaltete der Shelly Dimmer 2 die Lampen nach einigen Sekunden aus und zeigte Überhitzung auf der Benutzeroberfläche an. Die Kalibrierung wurde nicht abgeschlossen.
    Nach 10 Minuten Abkühlen wurde ein weiterer Kalibrierversuch gestartet. Die Benutzeroberfläche zeigte "Kalibrierung abgeschlossen" an.
    Nun das Problem: Nach einigen Minuten Betrieb der Lampen mit 65% Helligkeit zeigte die Benutzeroberfläche "Kalibrierungsfehler" an. Ein neuer Kalibrierzyklus wurde gestartet... wieder zeigte das Interface "Kalibrierung abgeschlossen" und nach einigen Minuten Betrieb wieder "Kalibrierungsfehler". Wenn die App zur Steuerung des Shelly Dimmer 2 gestartet wird, zeigt diese stets „Vor dem ersten Gebrauch kalibrieren“ an.
    Hat jemand ein ähnliches Problem mit der Kalibrierung, die während des Betriebs der Lampe nach einem erfolgreichen Kalibrierungszyklus "fehlgeschlagen" anzeigt? Hat jemand einen Tipp, wie man dieses Problem lösen kann?
  • Nein, kein Trafo... es sind 240V Birnen, direkt angeschlossen. Auch die Wattzahl ist weit unter dem Maximum. Sollte also überhaupt keine besonderen Anforderungen an den Dimmer stellen.
