Shelly motion always status "dark"
  • Hi Forum.
    I have several Shelly motion devices. All of them always show that the status is "dark".
    Even if I change the illumination definitions in the sensor settings, the device thinks it is dark.
    Does anybody have an idea what illumination definitions I could use to have the correct status displayed for bright, dusk and dark?
    Any help is welcome!
    has the mistake been made for all of them since the initial setup? Tried to reboot?
    What thresholds did you enter?
    According to my personal feelings, I chose 10 for dark and 250 for dusk.
  • has the mistake been made for all of them since the initial setup? Tried to reboot?
    Thanks @Olsche .
    I have used the default settings.
    To test, we have used 800 for dark and 1000 for dusk.
    ADDED:
    It works. Thanks @Olsche !
    What also helped was refreshing the Shelly app each time after changing the settings.
    2 Mal editiert, zuletzt von Elsdeniep (28. Juni 2021 um 14:15)
  • What is shown when you enter IPfromyourMotion/status in the address line of the browser?
    under lux: (as here in the example)
    value350
    illumination"twilight"
    is_validtrue
    Thanks for the ip-adress/status trick. That shows a lot of info!
