Can UNI be used as a door sensor with reed switch? What should be the wiring?
  • Hi,
    I have an electronic door lock with some outputs. 2 of them are ground and reed switch (N.O.).
    Is the correct wiring goes like this:
    > lock's GND wire connected to the DC (-) connected to UNI input 2
    > lock's reed switch wire connected to UNI input 8?
    if not, what is the right way?
    besides, the lock's manual has a comment that the reed switch wire cannot support load greater than 24V and 100 mA. Is this ok with the UNI?
    Thanks!
