Close/Open Blinds weather dependent
  • Hello,
    I've 14 Shelly 2.5 to control Blinds.
    Now that is almost Summer and the sun is very Bright I would like to control automatically the Blinds with parâmetros weather dependent.
    Is it possible, or is Shelly thinking on doing that?
    If not can you please apply on the schedule a selection box to choose manually and weekly the time that I what to close or open?
    As it is the app today, the only option is to delete or create schedules, so annoying and hardwork.
    Regards,
    Helder
  • Hi,
    i had the exact same problem and created this script for your Shelly 2.5. Please check it out and let me know if this works for you: https://github.com/gregorjakobi/S…r_automation.js
    In the config-part you can adjust the settings, simply copy it to your Shelly in the script section.
    You need an OpenWeatherMap API Key, which you can get for free, if you keep the interval low enough (up to 60 views per minute and a total of 1,000,000 views per month).
    I check every 5min and thats totally fine.
